Repair information and guides for the fifth generation of iPhone. Model: A1387
2201 Questions View all
Front facing camera freezes, not working!
Hi,
I keep reading the great solution for the iPhone 4 front facing camera issue after screen replacement, but nothing fo the 4S.
I did a screen replace on a 4S, switching also from white to black. Since then, the front facing camera just won't work. When I switch form the rear camera to the facetime one, i just get a blurred image from what was on the rear camera, but nothing active on the front facing camera.
I read about a small jumper that may have gone missing on the 4 version, but is there a similar jumper on the 4s that could have broken off? All the 4 version photographes are - of course- totally different from what I see on the 4s mobo. I already replaced the camera, but nothing still.
All help is greatly appreciated.
Score 1
Add a comment
Most Helpful Answer
The little jumper on the iPhone 4 when it goes you can't see the camera what so ever it would be stuck on camera shutter.. Was going to say change the camera but u have done that .. I would check u haven't damaged the pins on the motherboard
Score 1
Add a comment
I was wondering if there had been a solution to your dilemma. I too have the same issue with an iPhone 4s
Add a comment
Nothing yet then has anyone got a solution for iPhone 4s front camera fix
Add a comment
Add your answer
Eva Tahon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 7
All Time: 3,279
