1.86GHz or 2.13GHz Processor, 128GB or 256GB Flash Storage
147 Questions View all
Question Closed
Troubleshooting MacBook Air 13" water damage
Like many others, I also got hit by water damage in my late 2010 MBA.
Following all advise in these forums, I disassembled, cleaned (with 99% isopropy alcohol), dried and reassembled all parts following ifixit instructions to remove upper case. However no luck so far ;)
Magsafe LED light is dim pointing to a potential issue with I/O board. I've already tried SMC reset and tried to power up after disconnecting battery.
No visible corrosion or water damage inside. Before I order replacement parts, is there a way to troubleshoot battery or Logic Board? Any other things I can try out?
Thanks in advance.
Add a comment
1 Answer
Unless you have another one of these lying around, there's not much you can do. My advice: Order a new power port, and if that fixes it, then great. If not, replace the logic board.
1 Comment:
Thanks, I'll give it a shot with new power port.
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 592
