Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
434 Questions View all
My display seems dim. Is this normal?
When I compare the display on my iMac with an external LG monitor of the same size and the same age, the Mac display seems pretty dim and lackluster. Is the comparison fair; i.e., is it normal for an iMac display to look dim when compared with an external monitor? Or, does the bulb and/or other components need replacing?
Score 1
Add a comment
1 Answer
Chosen Solution
External video is not the same as onboard video. It is possible your backlight is failing - it will dim as it does (or it may just suddenly go out).
You're comparing Apples to Oranges.
If this answer is acceptable please remember to return and mark it.
1 Comment:
If it is the backlight failing, what can be done about it?
by
Add a comment
Add your answer
Dan Gold will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 124
