The current line of iPod touch comprises seven (7) different generations.
2619 Questions View all
Question Closed
Does not turn on when plugged in after screen replacement
Hey guys, was wondering if I could get some insight on a recent problem.
I have an iPod 4th gen 32GB which I got from a friend 1-2 years ago, and today I attempted replacing the screen. To my surprise nothing happened after I put it all together. I wonder if the version it was in has something to do with it. Anyway it won't turn on, won't charge, won't be recognized in iTunes and noting happens when I attempt to put it in DFU mode. I tried grounding the battery terminal and nothing happened. I think that all cables are attached and nothing is loose. Any suggestions?
Add a comment
1 Answer
Have you tested the output voltage of the battery solder points? That's what I would try next.
1 Comment:
Hi Joshua, I haven't tried that yet, could you give me some insight as to how I may do this?
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 77
