Repair information and disassembly guides for Sony PlayStation controllers.
965 Questions View all
Question Closed
Will a different V and mAh replacement battery kill my PS3 headset?
I have torn down my official PS3 headset to change the battery. The original battery is a 3.7V 1350mAh battery. Replacement ones are 4.2V 1800mAh. Will that burn / grill / kill my headset?
Add a comment
1 Answer
Chosen Solution
Ben Hamel, the mAh will not but I'd be a bit leery about the higher voltage. It may be okay for the controller to handle it, but you are looking at a 15% voltage increase. I'd try to match the recommended voltage a bit closer. You might get a bit of a better answer if you can tell us exactly which headset you own.
1 Comment:
The headset I own is this one : http://m.us.playstation.com/ps3/accessor...
The original battery was an LIP 1472 Li-Ion.
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 714
