Repair information and guides for the fifth generation of iPhone. Model: A1387
2201 Questions View all
Water damaged iPhone in recovery mode?
Okay so i was working patrol (Cop) when i got out of my vehicle my phone dropped in a puddle of water and i went home after a couple hours to put it in rice (uncooked). That didn't work so i tore down the phone cleaned it and put it back together. and it works. but when i turn it on it's stuck in recovery mode and when i plug it in to restore it, iTunes says error 3 after the process finishes. So i'm wondering if maybe the logic board is damaged or maybe the USB dock in the phone is damaged or whatever.
Help me please
Score -1
1 Comment:
Bruce, try a different computer and see if you get the same error. This will rule out any iOS issues. Also, how did you clean it? Make sure that you change the battery as well. Water damage can cause the weirdest errors. Usually if an iPhone is stuck during the firmware update, it is caused by baseband issues.
by
Add a comment
iPhone Error 3 – Unable to Join a Network
iPhones are a great invention but not without their share of trouble. Much like computers, iPhones offer the best that technology has to offer but not without a certain share of headaches once in a while. Most would still agree that this high tech device is well worth the small issues that arise once in awhile.
Wi-Fi networks are the lifeblood of the iPhone and sometimes Wi-Fi networks fail, have issues or are clogged up preventing the iPhone user from connecting as they normally would. The error message “Unable to Join Network Failure” (error-3) is an example of one of those small headaches that will require some troubleshooting. Just as a PC fails to connect the iPhone uses the same type of connections and requires the same method of connection.
If your iPhone suddenly displays the “Unable to Join a Network” or Error 3 there are a few simple steps you can take to quickly get your trusty device back up and running to keep you connected. If you are connecting to your iPHone through a router or Wi-Fi setting, it is always important to know your SSID in the event that you have trouble connecting.
The first step you will want to take is to renew the hotspot’s DHCP lease. You can do this by taking the following steps:
Tap Settings.
Tap Wi-Fi Networks.
Pick the network you are trying to connect to (i.e. Starbucks, Borders).
Go to the DHCP panel.
Click Renew Lease.
If this does not help you reconnect you should take the next steps:
Check the network name or (SSID) setting. SSID stands for Service Set Identifier which is the name of the network. The network and the device you are using must have the same SSID to allow the network and the device to properly communicate with each other. The SSID can be set manually or will be automatically entered if you leave the SSID blank. Make sure that it matches the network of the Wi-Fi or hotspot access point that you are using.
Check your iPhone security configuration to make sure that your WEP or WPA parameters match the access point. WEP stands for Wired Equivalent Privacy and WAP stands for Wi-Fi Protected Access both of which are part of the security settings.
To check your settings you can do the following:
Go to Settings
Wi-Fi Networks
Other
Under the Choose a Network tab
Enter or select the Wi-Fi Network Name (SSID)
Select your security setting
Enter your password
If all else fails you can try a different location or if you are connecting via a router you can contact the iPhone support for assistance with more troubleshooting options.
from here
keep me posted here the results..
good luck and thnx
Add a comment
Thanks for brisbane wholesalers' knowledge for iPhone error 3. If you fixed the network problem, you can use a quite easy and quick tool to exit iPhone recovery mode screen without plugging into iTunes, just one click to enter or exit recovery mode without effort. You may know the tool called ReiBoot, which is now downloaded by most of iPhone users to fix iPhone dead screen issues.
Get it from google if needed.
2 Comments:
reiboot finally got my iPhone 4s to come back on. it had power and was recognized in iTunes but had a black screen and the constant chime. It's now reloading the apps my son had on it and I guess I'll just have to reboot it several times a day. So thankful to know about reiboot!
by
Hi, Cade Baxter. I am glad that reiboot helped you out! Wish you a good and happy day!
Best regards,
Becky
by
Add a comment
Add your answer
Bruce will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 2,802
