0
Score
Avatar
Leigh
21
Asked
SSD drive--isn't the recommended 6gb replacement too fast for my mac?
History
I have a MacBook Pro 15" Core 2 Duo Models A1226 Santa Rosa 2007.
I do not understand something about data transfer rate in regards to me buying a new ssd hard drive from IFIXIT, which I want to do to speed up my old Macbook pro. From what I do know, the Data Transfer Rate is the rate at which data can be sent or received. This is determined by your motherboard. A drive with a higher transfer rate will only run at the rate of the motherboard's transfer rate.
If this is true, how come the ssd ifixit recommends for my Macbook Pro is a 6 gb one? Isn't this to fast for my old computer? Would it even work? Wouldn't a 3 gb ssd be better? Or perhaps even that would be too fast? I think my data transfer rate on my Santa Rosa could be even as slow as 1.5 gb. So I am very confused. Could somebody let me know if I would even benefit from upgrading to a ssd, and if so, what would be the best one for me to get?
I've read on other site and others when people put these "recommended" 6gb ssd drives in 2007 Santa Rosa machines like mine, they do not work. If this is so, why would IFIXIT recommend these drives for my machine. COLOR ME CONFUSED!! Please help.
Edited by: Walter Galan ( ) , Leigh ( )
Post Answer
Score
Avatar
Dan
45.7k
Answered
Accepted Answer
PermalinkHistory
The I/O connection between your current HD is SATA.
Within the SATA standard there is different revisions which is the real issue here. Each revision has increased the throughput i.e. SATA I (1.5 Gb/s), SATA II (3.0 Gb/s) and lastly SATA III (6.0 Gb/s).
The device's I/O speed (SATA) needs to match or be lower than the systems SATA ports I/O speed.
So, one needs to know the specs of a given device and if it is able to run at the systems speed. In some cases firmware updates are needed.
I would first update the systems EFI firmware. Review this Apple TN EFI & SMC firmware updates for Intel-based Macs.
Then, I would review the specs of my system by reviewing a trusted data base like EveryMac. Here's a link to your model and the different versions of it MBP A1226 SantaRosa.
Open up yours in the list and look under Standard Hard Drive. Open it up to see the specs. Did you find your systems SATA speed (Serial ATA)?
Now check out the SSD you are thinking of is it the same or can it be set or run at the same speed?
Add Your Answer
Today: 0
This Week: 1
This Month: 7
All Time: 52
