7.9 inch display / Model A1432 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
220 Questions View all
Ipad mini Lcd is on, however back light isn't. help!
I followed the front panel replacement guide from ifixit. Everything seem to go how the guide says. However after connecting the lcd back, it wont turn on. But it looks like i am able to see my lockscreen wallpaper and time, however no backlight is turned on. What can i do?
Score -1
Add a comment
Most Helpful Answer
There is an extensive thread on here that details a DIY jumper that can be made to turn your backlight back on--- but I always caution people to really consider just having a professional replace the fuse on the motherboard--it can be done easily and affordably with the right tools. You can find mail-in iPad mini backlight repair service on eBay if your local shop doesn't do it.
Feel free to contact me with more questions-- jessabethany@gmail.com
Score 1
Add a comment
Your back light filter is blown, that is a very difficult repair. You should take it to a local repair shop that can hand that type of repair.
Add a comment
The error may also be in the IC chip that was used in the replacement. You need to update to the most recent iOS and you also should attempt a new screen. Before sending it off, redo the job, but make sure the Mini is off. Do a soft reset. Do not use metal tools to release any plugs on the inside.
Add a comment
Add your answer
onesalvie will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 10
All Time: 317
