Repair information for the 6th generation iPod nano. Released in September of 2010. Model Number: A1366.
175 Questions View all
Why is my iPod nano 6th generation not turning on?
even if I charge it or hold the power button for three seconds it wont turn on
Score 3
Add a comment
Connect it to iTunes and see if it shows up. If it does, the display needs to be replaced. If it doesn't, it's a logic board issue. Also, for future reference, do not create multiple questions for one problem.
Add a comment
turns on with cracked screen but does not show up in iTunes.
Add a comment
Took my apart everything worked perfect but the on/off button so I fixed that and put it back w/ extreme caution but the screen turn all white w/ noting on it.
It does connect to I Tunes deletes and add song, plays from it but when I disconnect white screen only and it also does it when I plug the earphone jack aging white screen only
1 Comment:
Try seeing if you need to replace the on/off/volume buttons. there is a little spring right under the power button, causing the button to not come back up. Also, if you plug it in with a USB-iPod cable, it should turn on and operate normally until the backlight automatically times out(display dims to conserve energy). This means you need to replace your power/volume buttons (they all come in on part.). Thanks!
by
Add a comment
Add your answer
samuel will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 6
All Time: 3,457
