Nokia E90 is a 3G smartphone made by Nokia and the latest model of the Communicator series.
6 Questions View all
front light does not come on
hi
small amount of tea has been poured on nokia E90,,it has been working after some spray repair,only the front light does not come on?
What needs to be repaired?
thanks for your help
abi shahnazi
Score -1
Add a comment
1 Answer
Chosen Solution
Hi,
If you have problem with the light on the LCD, check first the connector between LCD and board. Because you have more power consumption through the pin for light may be you have burned, broken line. Second: you can have problem with the screen. Third: if you have problem with main board you must find LCD light line from schematic diagram.
Regards.
Score 1
Add a comment
Add your answer
abi will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 7
All Time: 444
