The Motorola Droid 4 is a smartphone made by Motorola that was released with Android 2.3 and is upgradeable to Android 4.1.
25 Questions View all
The screen is not lit, perhaps an issue with the proximity sensor?
The screen will not light to it's normal brightness. I can still see and use the screen, but not without straining my eyes or very low light. I think it may have to do with the proximity sensor dimming the display. I downloaded an app to check if the sensor was working properly, and it appears to be fine. It registers when something is nearby properly. I've done multiple restarts using the power button and the down volume key at the same time, but no results. I've also booted into safe mode to see if it was any recently installed apps, but again, no luck.
Score -1
1 Comment:
I've also now wiped the cache with the assisstance of a Motorola rep via chat. Still, no luck.
by
Add a comment
1 Answer
go to home screen. hit the menu button (small one on the left side at bottom) goto system settings. look for display and tap on it. look for brightness then look for adjust brightness level. turn off automatic brightness and drag the slider to the right. that sould fix it.
1 Comment:
Unfortunately that did not work. I'm beginning to suspect the backlight has died.
by
Add a comment
Add your answer
Rothmore will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 5
All Time: 242
