Repair and disassembly guides and support for dish washing appliances.
707 Questions View all
Question Closed
The best way to use a dishwasher
Please run the hot water in the kitchen sink before running the dishwasher. This will allow the maximum amount of hot water to enter the dishwashwer so it can do it's job properly. Also every 6 months take the spray arms out of the washer and remove the bits of trash that get stuck in the spray holes. Dirty water recirculates thru the spray arms and bits of trash get stuck in the spray holes. This causes bad spray patterns and improper cleaning and spraying. Using tweezers or hemostats can help quite a bit.
1 Comment:
FYI, if you phrase this as a question, and then answer it yourself, then accept your own answer, they give you a nice little badge which makes you feel happy. Nice post.
by
Add a comment
1 Answer
Before running hot water ensure your dishwasher has a hot water feed. Most modern dishwashers only have a cold water feed and heat the water as necessary.
Add a comment
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 1,775
