The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying. Released on March 11th, 2011. Model numbers: A1395, A1396, and A1397.
730 Questions View all
I dropped my iPad 2! it shows red white and blue colors
The side of my bed is against a wall. My bed had moved and my iPad fell thought the space between my bed and the wall. It was really late and I was tired so I just left it there not thinking anything of it cuz this has happened before. When I looked at it this morning it was broken. It works completely fine it just is all fuzzy and only displays the everything in blue red and white. I don't know what to do. Do I have to take it in to get it fixed? Can I fix it myself? How much is it going to cost?
Ps. The screen isn't even cracked it's just the colors it is displaying.
Score -1
Add a comment
Give the back of it a nice firm smack. That may fix your problem as the connector may have gotten loosened when it fell.
Add a comment
I think your LCD is broken..
because there was a pressure on your ipad glas, the glas touched the lcd what may occur the red white blue colors. This also happens when ipads falls from a distant.
It can also be your lcd cable what is loosened from the lcd connector on your logicboard..
But think its more your LCD :)
There is one way to figure that out and that is : exactly, open your ipad.
Because your ipad glas isn't broken its very hard to open glas from your ipad without breaking it.
If you didn't repaired ipad digitizer's earlier i suggest that you don't do this repair yourself.
What now ?
So you need a new iPad 2 LCD and Ipad 2 digitizer.. OR
If the cable is loosened and it works fine after reseating it, you only need a Ipad 2 Digitizer.
hope this helped you out..
Add a comment
Add your answer
Sarah will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 1,106
