Repair guides and disassembly information for Apple's Macintosh personal computers.
42797 Questions View all
Question Closed
How to fix a stripped screw?
OK. On my MacBook 13'' which is broken, many of the Philips #00 screws are stripped. I try to turn them with slightly bigger screwdriver that has worked for them in the past, but the screwdriver just doesn't grip the screw hole. I don't have a dremel, nor do i have super glue easily on hand. what do i do?
1 Comment
I literally tried EVERYTHING. I tried the rubber band trick, holding down on the top of the screwdriver, i even tried a hammer to push the magnetic screwer in the void of the screw. NOW WHAT?!?
by
Add a comment
1 Answer
Most Helpful Answer
Depending on how stripped the screws are, you may be able to put a rubber band between the screw and driver to see if it can give you some grip.
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 327
