Repair information and guides for the fifth generation of iPhone. Model: A1387
2201 Questions View all
Question Closed
How do I diagnose a short?
Hi!
I have an iphone 4s that had some water damage. I'm new to repair, but I'd like to do what I can. I
Basically, I can charge it, but it drains quickly and twice it's killed a battery when the battery got low. It's a little warm on the silver plate that is near the rear camera. I ordered a new rear camera, but how do I know if that's what's causing the short? What if it's something else? What can I do to figure it out?
Any advice at all would be great.
Add a comment
Most Helpful Answer
Bree, you may not have any corrosion (yet) but you may have some short circuit. The very first thing I suggest is to start off by cleaning the logic board properly and replacing the battery re-evaluate after that. Use this guide to clean your iPhone. It was written for a 3G but all the points apply to your phone as well. These guides will help you disassemble your phone. Check for broken, missing or charred components.This is a must before anything else.
Score 2
1 Comment:
Hi, In case anyone wondered: I took my phone apart, there wasn't any corrosion or water evidence EXCEPT for... the phone was getting hot in the upper right hand side, (opposite side from rear camera.) I looked around and the water indicator sticker was DARK BRIGHT RED. Whoops. So I bought a new headphone jack and was going to replace it... AND THEN I accidentally tore the power cable. So had to replace that, too. I've ordered a new battery. Hopefully without the headphone jack shorting it out, it might actually last longer than 4 hours.
Anyway. In case anyone wonders, I couldn't find 99% alcohol. But I did find 91% and that seemed to be fine.
Have a great day!
by
Add a comment
I'd take the logic board out and check it thoroughly for dark spots and corrosion. Have you soaked your logic board in isopropyl alcohol yet?
Score 1
Add a comment
Okay, I'll do that! Thanks for the advice. :-)
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 153
