Second generation of CDMA iPad 2 with 16, 32, or 64 GB and Dual Core A5 Processor. Model Number A1397. Repair is detailed and requires heat and prying.
52 Questions View all
Question Closed
Ipad 2 Screen Repair Test
My Ipad 2 digitizer was cracked. I removed it to replace it. I damaged the Volume, power, hold cable. I replaced the cable but I am not sure the power button is correct.
Is there a way to test the button without putting everything back?
Add a comment
1 Answer
for me no!
just try this method
just put the power flex in the slot, then put your logic board in the propare way, then put only 1 screw in the battery terminal, then put the lcd back without fitting any screw, then try to press the power button if it working or not.
sorry for my english.
hope this can help to you.
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 262
