Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
iPhone 5 stuck in headphone mode after disassembly
Hey guys!
I have a white iPhone 5 16GB on iOS 7, and it's power button was broken. I replaced the flex and now everything is is perfect, except for the fact that the phone believes that is has headphones plugged in, so it wouldn't play any sound trough the normal speakers. I could verify that the speakers do work by putting the phone to speaker mode during a phone call. When I adjust the volume, it says headphones too.
I pretty sure it's my fault. What would be your guess, what could I have possibly mistaken so that this is the result?
Score 1
Add a comment
Try sticking some headphones in, twist them around a little, and see if that fixes it. You probably got something stuck in it.
1 Comment:
This was my first idea too, but it didn't work. It looks clean too.
by
Add a comment
you probably broke the flexcable of the dock connector. replace the dock connector and your headphone jack should be ok
1 Comment:
I happen to have had a spare dock connector lying around, and I've just tried it. Without success. :( Any other ideas?
by
Add a comment
Did you find a solution?
2 Comments:
nope still stuck in headphones mode. got the same problem as the poster!
by
I have same issue , I used qtip dipped in rubbing alcohol . It worked but
When I turned iPhone off and on problem returned !
by
Add a comment
Add your answer
martongr will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 1,043
