2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
561 Questions View all
Question Closed
Replace Keyboard Button (caps lock & one button)
Hi to all,
Is it possible to change out only button (no the entire keyboard) on Retina 15"?
I have a burned CapsLock and one other button and want replace it, it is possible?
Add a comment
Chosen Solution
Here's a source I use to get new key caps TheBookYard.
If on the other hand you have damaged keyboard (the innards) so a few keys just don't work. Then your in for a big repair job if you can salvage the keyboard or not.
You see the keyboard is the very first part installed, hence it's the last one to come out. Besides Apple really anchored the keyboard down with a ton of screws and/or rivet pins (depending on the model). Then if you are able to get the keyboard off its still a lot of work taking it apart to get to the pads inside to clean them (assuming they are only dirty). If the given key pad set is damaged there is no way to repair it.
Bottom line here its just easier to replace the top case Vs trying to repair or even replace the keyboard (presently they are not available by them selves).
Score 1
1 Comment:
No i ve only burn caps lock and one button whit sigarette and i want change it.
I found the button of mbp , it is compatibile whit retina 15 ??
by
Add a comment
Most Helpful Answer
It is possible, but quite tricky, scissor mechanism keyboard is difficult to install
Score 1
1 Comment:
tnks for the reply.
But the button of keyboard are the same of macbook pro ?
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 3,493
