1.86GHz or 2.13GHz Processor, 128GB or 256GB Flash Storage
147 Questions View all
No backlight after replacing screen
Hi guys,
I've had the same problem with my macbook also no backlight. I've bridged the fuse and it's reading 8.0V so that is not the problem. Can anyone else give me a push in the right direction.
Much appriciated.
Score 1
1 Comment
carefully check your LVDS socket and the LVDS connector for any damage. Often a short on the logic board can damage these parts so even if the fuse is bridged power wont reach the screen backlight.
by
Add a comment
1 Answer
Most Helpful Answer
Ir might be burnt out on the display. BTW bridging the fuse is risky, you can burn out other parts of the board (maybe start a fire).
If this Answer is helpful please remember to return and mark it Accepted.
Score 1
3 Comments:
Hello machead3,
thank you for your answer, could you please explain what you mean with "IR".
I'm not the one who is bridging, a friend of mine who has a lot of experience with this is performing the labor.
Is there any way i can get a schematic for this model?
by
I lost the source but someone reported doing this (bridging fuse) then seem surprised that smoke was pouring out of another spot on the board. Bridging the fuse isn't the problem...that the fuse can no longer function is the problem.
by
What I meant was the replacement display also has a defective backlight.
by
Add a comment
Add your answer
Zakaria will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 281
