1.8GHz dual-core Intel Core i5 (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
371 Questions View all
Question Closed
What did I mess up with my hair dryer?
I bought my MBA already liquid damaged (broken battery, keyboard, and trackpad.) I guessed that I could just clean it out and fix it. And the price was right so that if I couldn't then I could sell it for parts for no loss. I followed a guide to cleaning off circuit boards, ribbons, etc. Used 92% alcohol and a toothbrush. After reassembling (triple checked everything) I couldnt hear the fan spinning on startup, but everything worked perfectly. it was charging and the keyboard and trackpad worked. But the mba was unuseably slow. Further research brought me to the conclusion that there was still liquid and that I should dry it off. I was advised to use a hair dryer on the cold setting. My hair dryer doesnt have a cold setting so I used it normally. I let the macbook sit for awhile and then tried to start up. Nothing happened. Completely bricked. Did I over heat something? Logic board? ISO? SSD?
Add a comment
1 Answer
Its possible that you delaminated the board, if so you have ruined it and need a new MBA or possibly a new motherboard, but at this point buying a new computer is probably going to be easier and cheaper.
Hope this helps,
John H. Laney
Add a comment
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 9
All Time: 843
