Score
Avatar
Robert Antoine
45
Asked
No Sound from Mac Mini!
History
I have a new problem that involves no sound coming out of the Mac Mini's speakers. When i received my Mini from the seller there was a gap to the rear of the unit as the party before me did not reassembly the top cover all the way. I gave it back to have the cover fitted correctly and now after powering on the unit I recognise that there is no sound, and plugged in some external speakers and got sound for just about 2mins then a lot of static. I then purchease a putty knife filed the edges and opened the case, but I found nothing that seemed like it was out of placeso I reassembeled.
Any suggestions?
Edited by
Post Answer
3
Score
Avatar
markus weiher
21.4k
Answered
Accepted Answer
PermalinkHistory
sounds like a problem with the audio board
maybe you should open the mini again and look if there is something odd with the board or the connection
Score
Avatar
garyobrien
25
Answered
PermalinkHistory
I had the same problem with a Core Solo machine. Turns out the people who installed some RAM (this was before I discovered ifixit) had not properly seated the ZIF cable in its socket.
Steps 7 and 8 in the Audio Board install (Installing Mac mini Model A1176 Audio Board) are where the solution lies.
There is a painted line on the ZIF cable. Before you close the cable lock, make sure the cable is fully inserted - the painted line will be about 1mm above and parallel to the top of the socket. Push down the clip and all should be well.
0
Score
Avatar
Jacob Buchardt
Answered
PermalinkHistory
Thanks Gary, this was exactly it!
0
Score
Avatar
Dan Elazary
Answered
PermalinkHistory
I had the same problem with my MAC MINI A1176 Audio Board so instead of opening the case again I have scarified 1 USB socket and inserted a USB audio divice and it works just fine.
a internal can cost a 30 $ on eBAY but a USB dive can cost you 5 $.
Add Your Answer
