Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
250 Questions View all
iPad 2 adhesive does not stick to frame!
Hello!
I need some help!
I just replaced my digitizer. My adhesive does not stick on two of the corners (Down and top left corner) and almost to the home button (from corner to home button). I just do not want to open it up again. So i wonder if I can just use super on therse places and let it dry upside down?
Or is it other possible ways to fix it?
Thanks!
Erlend
Score -1
Add a comment
1 Answer
Chosen Solution
Glue does not work because glue need a rough surface to adhere too and glass is smooth. use 2 sided tape everywhere there is a edge, you may have to tuck the glass digitizer ribon in to not cause a spring effect so glass does not come up on the lower left.
Score 1
Add a comment
Add your answer
Erlend will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 177
