Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
433 Questions View all
Replacement Power Supply Options
So I am pretty sure the iMac im working on has a faulty power supply. The original 240W power supply shows a trickle charge (1 led) when installed, and when you try to power on the computer LED's 2 and 3 flash quickly (less than 1 second) then all 3 go out. I purchased a replacement PS 614-0432 which has all the same connectors, but is rated at 250W. After installing it I believe the replacement is defective anyhow (2nd hand part) as I don't even see a trickle charge LED.
After doing some looking I see it's next to impossible to find an original 240W power supply (614-0405). I see lots of people recommend the 661-4478 power supply which is also rated at 250W. I was wondering if anyone has replaced the original power supply with a newer higher wattage PS without any issues, I'd really like this to work on the second shot. Any insight anyone would have would be great! Thanks!
Score 1
1 Comment
Did you ever find the solution? as I have the exact same issue
by
Add a comment
1 Answer
Chosen Solution
Seems legit - but there's a tech note you need to have/use the new power wall too.
If this Answer is helpful please remember to return and mark it Accepted.
Score 2
Add a comment
Add your answer
Bob Mintern will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 2,065
