First-generation Apple iPad with Wi-Fi, available with 16, 32, or 64 GB. Model Number A1219. Repairs are straightforward and do not require heat.
130 Questions View all
Can I just replace my 30 pin connector without the ribbon assembly?
Is it possible to just replace the 30 pin female connector on my iPad without getting the entire assembly?
Like if I bought this could I just replace the connector.
http://www.ebay.com/itm/30-Pin-Female-Co...
My assembly is fine just the pins on the connector are bent so I was hoping to save some money.
TL:DR: Can you remove the 30 pin connector from the ribbon cable?
Score 1
Add a comment
1 Answer
Chosen Solution
only if you have the skills and the tools of soldering 34 very fine points without making a mistake. If you do not have the tools and or the skills, I suggest that purchase the assembly.
Score 2
Add a comment
Add your answer
John will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 11
All Time: 1,031
