2.5 GHz dual-core Intel Core i5 processor (Turbo Boost up to 3.1 GHz) with 3 MB shared L3 cache.
265 Questions View all
wine on mac : screen and battery charger out of order
I AM FRENCH, PLEASE DON'T MIND OF MY BAD ENGLISH !
Hi, after quarter of a wine glass falling down on the keyboard of my macbook, and let make it dry (inverse position, towel..) the macbook pro can turn it on blindly (screen not working, almost no liquid on the screen in the accident), i can launch music, and it don't turn it off.
When i try to plug the battery charger, nothing happen, no light.
What can i do ? I read that i can open it, clean it with some special products, and it could supernaturally work after. I also read i can try with a multimeter to find where the connection turn it off, .. (it seems very dificult, specially because i read some part don't have to be tested, and then if i find something, i won't know how to change a connecting thread .. waowwe it's professional!).
Anyway, i would like to try my best to fix it.
Best Regards,
Thierry
Score -1
1 Comment
What was it a White or a Red wine?
by
Add a comment
1 Answer
Chosen Solution
First you will need the tools to open the system as well as an ESD mat to work on.
To start with you need to disconnect the battery ASAP as having it connected can make things worse. Follow the iFixIt guide on removing it.
You will need to get a few things to clean the wine out. Distilled water (not tap water), 85% isopropyl alcohol, some baking soda, cotton swabs (buds), & can'ed air.
Depending on how much wine is still present you may need to neutralize the acids in it. Mix in a separate container some of your distilled water and baking soda (1 part soda to 20 parts water). Don't use all of the distilled water as you'll need it to clean things as well.
Using the cotton swabs wipe down the areas you see anything wet or stained with straight distilled water. I would hit the exposed contacts & solder joints with the baking soda cleaner if you had a lot in any one area. You will need to go over these areas again with the distilled water to remove any remaining baking soda cleaner. Then go over the areas again with the isopropyl alcohol this will help in drying any remaining water under the components as well as use the can'ed air.
You will likely need to pull the logic board out to get to the other side. You can review this iFixIt 13" MBP Retina teardown to get an idea how things come apart. Follow the other guides as needed.
Just be careful as you wipe the logic board that you don't snag any thing or pull any components off.
Take your time and make sure to have a plastic egg carton or two to hold the small screws. Take some pictures of any areas you have concerns and we'll try to help as best as we can. It's likely the keyboard is damaged to the point it can't be saved you'll need to order a new top case to get a new one. Hopefully the battery was low so it didn't add to the damage.
MacBook Pro 13" Retina Display Late 2012 Image
Guide
MacBook Pro 13" Retina Display Late 2012 Teardown
Difficulty:
Moderate
MacBook Pro 13" Retina Display Late 2012 Battery Image
Guide
MacBook Pro 13" Retina Display Late 2012 Battery Replacement
Difficulty:
Difficult
30 minutes - 2 hours
Score 1
Add a comment
Add your answer
utilis ateur will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 5
All Time: 386
