The Kindle Fire HD 8.9” is a tablet computer that allows users to read books, view comics, watch movies and find general entertainment at a mid-range price. Fixes are simple and do not require any special tools.
54 Questions View all
Replaced USB Charging port but kindle still not charging. Any Ideas?
I have a Kindle that will not charge. The usb charging port was loose on it, well not loose, it had no connection to the board. I soldered it back into place and put the kindle back together and plugged it in. No change. I further examined the usb port and decided that maybe I should try a new one. Got the part in, successfully soldered to board but still can't get the kindle to charge. I am at a loss right now and need of some help.
Score -1
2 Comments:
I have tried plugging it into the computer, a different power supply and wall plug in.
by
Have you check the traces on the logic board at the connector for any current?
by
Add a comment
Hello!
If the repair was definitely successful then it's time to cross the kindle of the problem list... For Now.
It is possible that the charging unit (PSU) is faulty, have you tried charging the kindle through USB connection using a computer?
Add a comment
Where did you get the charging part from that is exactly what I am looking for.
Add a comment
forget it..... the tiny membrane connectors between the screen half and the bottom part are virtually impossible to connect back properly once you pry apart the case. The device will be destroyed.
Add a comment
Add your answer
Gabi Quaranta will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 1,037
