Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
How can I assort all the screws of my iPhone 5?
Ok here is my problem. Ive bought an used iPhone 5, with some screws missing. So of course I want to replace those missing screws and bought a package with all the 54 iPhone 5 screws. Does anyone got any idea how I can easily find out which srew has to be add where? I started with assorting the bigger ones, but below 2,5mm its very difficult to see a difference between the srews. Is there maybe a complete overview or model of all iPhone 5 screws? Thanks in advance!
Score 3
Add a comment
Chosen Solution
I went through this with a 4s where all the screws from two phones got mixed up when a table was bumped. In my case, I bought a set of screws for baseline comparison.
I took a sheet of paper and drew squares, looked at the repair guide, and wrote in each square a size and number of screws. Last, I used a micrometer to measure each screw and place it on/in the square on a piece of paper.
Later, I used a little plastic (think fishing lure holder) clear box and labeled each compartment where I placed screws from a couple extra sets that I had ordered -- never know when you might lose one.
It takes a bit of time but better than shooting in the dark.
Score 4
Add a comment
If you go through the iPhone 5 guide list and follow each guide for the areas where the screws are missing, the guide tells you what size each screw should be, a micrometer but be needed.
iPhone 5
Just work through it one be one and you will get there, an important thing to note, if at any time there is a little too much tension on the screw STOP as this will be the wrong screw.
Please let me know how you get on.
Cheers
Brendan Mills
Score 1
2 Comments:
Thats what I tried first, does the guide tell me the length or the size of the screw?
by
Yes it does, every screw will have a size stated in the guide
by
Add a comment
Same happened to me dropped all of them
Add a comment
Securing and keeping track of those tiny screws:
  1. Before removing any screws from any device:
    • Read through the guide!
    • Write down the each step number that has screw removals
  2. Beside that step number:
    • Write the screw sizes
    • Write totals for each size
  3. Create a “tack strip”:
    • A strip of masking tape, long enough for each step with screw removal
    • Secure the “tack strip”your work surface, STICKY side UP
  4. I secure the “tack strip” to the work surface along its top and bottom with more masking tape pieces.
  5. On the top strip:
    • Write the step number
    • Write the other info about the screws
  6. Draw a line from the top strip, across the “tack strip”, and all the way to the bottom strip.
Additional tip: Do not work over a carpet! ;+)
Add a comment
Add your answer
Rob will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 8
All Time: 11,545
