0
Score
Avatar
twisir22
Asked
iPhone 5 Doesn't Charge Or Turn On
History
Hi everyone. I have an iphone 5 that wouldn't charge. Hard resetting didn't work. It just wouldn't power on or charge. The phone is approximately 3 months old. I can't go to Apple because I went before and they told me that the phone looks like it have been tampered with so the warranty is void. To my knowledge, Apple techs were the only individuals to go inside the phone. They said that a coaxial wire was broken. I finally looked inside last night and saw that the interconnect cables were broken, but to my knowledge the interconnect cables have nothing to with the device receiving power. Different lightning connectors have been tested, so it doesn't seem to be a lightning connector issue. I have tried putting it into the comp and the adapter and on both accounts, no avail. It must be a hardware problem. Could anyone please give me insight as to what components are responsible for delivering power to the phone? Does anyone have a knowledge as to where the inductors are located? May Jesus bless you and thank you for your time.
Edited by: twisir22 ( )
Post Answer
0
Score
Avatar
paulinsight
Answered
PermalinkHistory
If you haven't done this as yet, try holding the Sleep/Wake button and the Home button both at the same time for around 15 seconds.
I tried a soft/hard reset already. Thanks for your reply.
twisir22,
0
Score
Avatar
Amin Ghaziaskar
Answered
PermalinkHistory
I have the same problem, although mine happened after I used iPhone to %0 and now it neither charge nor turn on
have you found any solutions ??????
Nope no solutions. Most likely it's the power management ic.
twisir22,
0
Score
Avatar
Wisdom Banks
73
Answered
PermalinkHistory
Open your phone and take out the battery . Use at least five volts of power to kick the battery for about 2 minutes. Connect the positive to the the first terminal( the contact near the dock) and the negative to the third terminal or the last which is the ground . Connect back and power on, it's should indicate low battery. You should now be able to charge.
I tried it and no avail. The battery seems to be receiving charge but my charger seems to be outputting an insufficient amount of voltage so this process might take longer.
twisir22,
0
Score
Avatar
Natalie
Answered
PermalinkHistory
might need a new lightning port charger. also, try removing the battery and then connecting it to itunes. if itunes recognizes it, it's not the port charger.
www.liljohnnyappleseed.com
Add Your Answer
Today: 4
This Week: 19
This Month: 138
All Time: 2,614
