The HTC Inspire 4G is the first smartphone available on AT&T Wireless branded as "4G". It's nothing more then an Desire HD locked to AT&T and running AT&T Software.
12 Questions View all
Can I replace just the charging port on my inspire?
I have 3! HTC Inspires all with different ailments but the most common is the charging port goes out and it wont charge anymore. I have one with a functional port but a broken screen so I would like to swap the good port to a cosmetically worthy Inspire from my “collection.”
Any suggestions?
Score -1
Add a comment
Larrissa, yes you can, but you need to know how to solder. Unsolder the old port from the "most broken one" and replace the one on the phone you want to use. Or you could just get a few new ports. Those are readily available on ebay and many other places. Check this video for the disassembly. hope this helps, good luck.
1 Comment:
The mini usb port soldered onto the board can be replaced?
I thought only robots could squeeze into small solder joints like that?
Has anyone done it?..'cause I have the same problem....
by
Add a comment
Here is a place you can purchase the charging port?
http://www.ebay.com/itm/HTC-Inspire-4G-C...
Add a comment
Add your answer
Larrissa will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 3,417
