Repair information and guides for the fifth generation of iPhone. Model: A1387
2201 Questions View all
iPhone4s is overheating and drains battery fast after water damage?
The phone was dropped in a pool. It went 10 feet deep but was fished out right away. My friend put it out in the sun to dry for 2 hours.I dried it on the inside by carefully drying the internal parts excluding the display area with a paper towel, then putting it a mixture of rice and packets of silica gel to absorb any left over moisture, but i didnt receive the phone for about a day, so there wasnt much inside. i replaced the battery and it turned on but it would burn up charge faster then it would receive charge. also the antenna dead, i think that might be related to it, but I put it in airplane mode and it still continued to use juice. Perhaps a short within a non essential part? I have disassembled the phone and reassembled it when i was drying it. I was able to turn it on and it worked but it burns energy faster than I can charge it. I have tried disconnecting a few parts and then plugging it in but it still heats up so it isn't the camera or the buttons.
Score 1
2 Comments
How did you clean it? What have you done to prevent corrosion?
by
I cleaned it with a paper towel. I didn't clean in deep because I didn't want to mess with the sensitive parts. I put it in silica gel packets and rice to remove any remainder
by
Add a comment
Chosen Solution
vanish172, even so "10 feet deep but was fished out right away." I suggest that you clean it. It really does not matter how much water exposure it had, or how long the exposure was. what matters is which part was exposed. A "mixture of rice and packets of silica gel" are a great first aid, but they will not prevent corrosion. Disassemble your phone use this guide, and clean every part, connector and cable with 90%+ isopropyl alcohol. Make sure that you remove any EMI shield. Use a soft brush to clean the connectors and cable ends properly. Check for missing or burned components. Once it is cleaned, replace the battery. After that, reassemble your phone and re-evaluate. Until you know for sure that it is clean, any answer will most likely be a guess only. Hope this helps, good luck
Update
here are a few items you want to check as well. I hate to refer to those as fuses, but they most certainly control part of the charging circuit. First one is reference designator L3, it is a FERR-120-OHM-1.5A inductor. L4, right below it , has the identical value. Next would be the charger inductor L28 2.2UH-1.8A-155MOHM. All of these are pretty much available at mouser. com or digikey.com. Hope this helps, good luck.
Score 1
4 Comments:
Do I have to replace the battery again? And thanks I'll try this and get back to you when done.
by
since you just replaced the battery, I would keep it , for now.
by
I cleaned the logic board and checked it. The heat is coming from the top of the phone and in the area of the WiFi connector
by
I'm having a lot of trouble getting the EMI shields off. Is there an easy way to do it
by
Add a comment
It was the WiFi Bluetooth chip that was acting up, I cleaned it once and nothing changed. Cleaned it a second time, turned the phone on without the EMI shield and its not overheating.
1 Comment:
Excellent job, congratulations on having a working phone. Best of luck to you and thanks for accepting my answer.
by
Add a comment
Hi
After a long time of diagnosing the same problem on my iphone 4s finaly found a solution and fixed the fault by changing the charge port with a new one
I suggest you do the same thing and change the charge port
Regards
1 Comment:
Wi, check the answer by vanish172 from July 17, 2013. "It was the WiFi Bluetooth chip that was acting up" This is the importance of reading all the answers and comments.
by
Add a comment
Add your answer
vanish172 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 7
All Time: 14,374
