changed lcd digitizer and data cable, still no fix for screen blackout
Hey guys,
I followed the manual to fix and change over the lcd digitizer and the display cable, but i still have the same problem. Whenever i set the display brightness past 4 levels, the screen will eventually go black and i will have to lower them to 1 then set it back under 4 levels. Would anyone know what else could be the problem? (i also fitted the cables in nicely, so i don't believe that it the cause).
Score -1
Add a comment
1 Answer
Chosen Solution
The only thing left is your LCD I believe that the backlight is failing... replacing the backlight is a very advanced DIY project Replacing the entire LCD is difficult but not so nearly impossible for a DIYer.
Check on price and availability to determine if it's economically feasible to replace the screen.
If this Answer is helpful please remember to return and mark it Accepted.
Score 1
4 Comments:
so what exactly would i be replacing? the lcd as a whole or a specific part of the lcd?
by
Easiest DIY fix - replace the LCD (backlight included). While it is possible to replace only the backlight it is a very advanced DIY project.
by
so just wondering where would i find out how to do the advanced way diy of the lcd? im sure i'd be capable if i had a guide to follow
by
Did you bother to look at the guide? There is a graphic on the right side just under the banner head.
by
Add a comment
Add your answer
James will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 6
All Time: 202
