0
Score
Avatar
KmkZ
11
Asked
changed lcd digitizer and data cable, still no fix for screen blackout
History
Hey guys,
I followed the manual to fix and change over the lcd digitizer and the display cable, but i still have the same problem. Whenever i set the display brightness past 4 levels, the screen will eventually go black and i will have to lower them to 1 then set it back under 4 levels. Would anyone know what else could be the problem? (i also fitted the cables in nicely, so i don't believe that it the cause).
Edited by: KmkZ ( )
Post Answer
Score
Avatar
machead3
68.7k
Answered
Accepted Answer
PermalinkHistory
The only thing left is your LCD I believe that the backlight is failing... replacing the backlight is a very advanced DIY project Replacing the entire LCD is difficult but not so nearly impossible for a DIYer.
Check on price and availability to determine if it's economically feasible to replace the screen.
If this Answer is helpful please remember to return and mark it Accepted.
so what exactly would i be replacing? the lcd as a whole or a specific part of the lcd?
KmkZ,
Easiest DIY fix - replace the LCD (backlight included). While it is possible to replace only the backlight it is a very advanced DIY project.
machead3,
so just wondering where would i find out how to do the advanced way diy of the lcd? im sure i'd be capable if i had a guide to follow
KmkZ,
Did you bother to look at the guide? There is a graphic on the right side just under the banner head.
machead3,
Add Your Answer
Today: 0
This Week: 1
This Month: 4
All Time: 97
