The HTC MyTouch 4G is an android smartphone that was released on November 3rd, 2010. The phone was also known as HTC Panache 4G in Canada.
5 Questions View all
Phone got wet, works fine for 5mins, then screen goes black...HELP!
I had my phone in my apron at work. I spilled a bucket of water with sanitizer on myself and in my apron. My phone was a little wet, but wasn't soaked, it wasn't dripping with water. I took my phone apart and put it plus battery in uncooked rice, overnight. Next morning, phone turned on fine. Was a little slow when pressing the touchscreen. After 5mins, the screen turns black and grey, and I have to take battery out then put back in, to see the screen again. The phone still rings, and I can talk on it, but screen wont stay on... Please help!! Can I salvage this phone?? Thanks so much-Jess
Score -1
Add a comment
Most Helpful Answer
jess, just like any other electronic device, I suggest that you clean it. It really does not matter how much water exposure it had, or how long the exposure was. what matters is which part was exposed. Disassemble your phone and clean every part, connector and cable with 90%+ isopropyl alcohol. Make sure that you remove any EMI shield. Use a soft brush to clean the connectors and cable ends properly. Check for missing or burned components. Once it is cleaned, replace the battery. After that reassemble your phone and re-evaluate. Until you know for sure that it is clean, any answer will most likely be a guess only. Hope this helps, good luck.
Score 1
Add a comment
I too have the exact same phone and it seems to be working fine but the screen is completely black while I can raise my volume up and down but dont have a contract for the phone anymore or warranty any ideas on what I should do
Add a comment
I have the same problem when I turn on my phone it shuts back off what should I do
Add a comment
I was a regular on the UseNet group Alt.cellular and other cell phone groups, almost every cell phone that got wet were pretty much history.
I went swimming with my MyTouch 4G, you could see the water level through the screen - did the suggested procedure: Took it apart, dried it out as well as possible, wrapped it in toilet paper, then buried it half way in a Quaker oat container that was full of rice and left it for a month (purchased a new phone in fact due to alt.cellular.).
The battery unfoiled itself due to the water after a few months, a year later I needed a phone and bought a new battery for the MyTouch and hoped a lot. It's been working just fine for 6 months now. The USB port was worn and I did have to devise a way to recharge it (posted it on this site: MyTouch 4G cell phone not charging [Solved]).
Being some 3 years ago I imagine you just purchased another phone...
Add a comment
Add your answer
jess will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 13
All Time: 2,206
