Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
630 Questions View all
Built-in speakers do not work (water, headphone-output/...)
Yesterday my iPad mini was together with a bottle of water in my bag which was not closed. The iPad got wet and now the speakers do not work, but if i put my headphones in the output i can listen to music (only on the headphones).
Do somebody know how I can fix this problem?
Thanks for your help and best regards,
Dominik
Score 1
Add a comment
Most Helpful Answer
doschaumburg, "The iPad got wet " to avoid any further damage, I suggest you no longer try to charge or turn your iPad on. this could cause further damage. What yo want to do is to clean your iPad's logic board with 90%+ isopropyl alcohol. Use a small soft brush to clean all the connectors properly. You did not tell us exactly which Mini you have, so use the proper guide from here. Check the logic board for any damaged, missing or corroded components. Once it is properly cleaned, I would also replace the battery. These batteries do not tolerated water well and can fail later on because of water damage. After that, reassemble your iPad and re-evaluate. Water damage could cause your speakers to fail, but you could also have a damaged audio IC. Hope this helps, good luck.
Score 2
Add a comment
Hi Dominik !
Mabe are your speakers dead. You may try and give your iPad a deoxidizer bath. If this doesnt work, you may replace the speakers. This part is not available on iFixit (for now) but unfortunately, things happen...
Hoping to have helped you !
Vincent
Score 1
Add a comment
I need help I think some milk got spilt on my iPad mini 2 and the sound does not work in less I plug headphones in!!:(
Score 1
Add a comment
Hi dominic,me too my ipad gets wet because the baby cologne of my baby
So speaker and headphones didnt work...please help me whatshould i do
To my ipad2
Add a comment
Add your answer
doschaumburg will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 50
All Time: 7,745
