1.4GHz or 1.6GHz Processor / 64GB or 128GB SSD
162 Questions View all
damaged LED backlight fuse while replaced LCD
Dear Fixers,
my model a1370 srnr. DQX has a damaged backlight led fuse on the logic board, maybe someone can place a sign on the pictures i uploaded and tell me which one is the led fuse and how I replace it the best way,
lcd Panel works perfect!
thx a lot,
Score 1
Add a comment
1 Answer
Chosen Solution
HJS, this is what I found on my schematic. I would still like to triple check, so a good part number for the logic board would be great. Anyhow, you will have to solder the fuse. It is an SMD component and as such not an easy fix, but not impossible if you have some soldering experience. Hope this helps, good luck.
Score 2
2 Comments:
that`s what I expected i just needed some professional advice to go sure ;)
thx a lot oldturkey
by
Hey HJS
Did that component replacement work with you?
by
Add a comment
Add your answer
HJS will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 1,782
