An easy to use home Espresso machine created by Saeco and rebranded for Starbucks. This machine is excellent for every day espresso drinkers and has an excellent build and product life.
140 Questions View all
Runs when the steam or expresso option not pressed
Sometimes the machine seems to be on expresso or steam even though the button is not depressed. It is like the button is pressed and you hear the pump going but neither button is pressed to on
Score -1
Add a comment
1 Answer
Hi Dick, make sure your hot water / steam knob is closed as tightly as possible. If this is opened just a little bit then it will activate the pump. If the knob has slipped out of position and is activating the switch no matter what you'll need to take the top off of the machine and reposition the knob on the valve via the hex nut on it's shaft.
Add a comment
Add your answer
Dick Conley will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 117
