Stuck on screen with Blinking file sign a question mark in it.?
when i turn it on all it does is show a screen with a file on it that has a question mark in it. Dont think its the drivers because there is no clicking noise. sounds like its booting up but just stays on that screen.
Score 1
Add a comment
Chosen Solution
Felicia Haze, the ? over a folder indicates that no valid bootable system was found. This could mean that your HDD has failed, or that your filesystem developed errors. The first thing I would do is to run Disk Utility and attempt to Repair Disk from the DVD that came with your MBP.
Score 3
2 Comments:
dont have the disk. didnt get one because i bought used. im pretty sure thats what happened i was deleting a file and the power chord came out an it turned off wen i restarted it thats all it would do and all its been doing since. any ideas about what else i could do or where i could get a disk?
by
Hi Felicia, Contact Apple with your computer info and they will sell you a copy of the original OS for about $15, Good luck.
by
Add a comment
Hi
I would take the information from the other answers and if that doesn’t work try this
Turn the mac off and back on again but hold the ALT button once you hear the chime and select the boot drive if it’s there.if it isn’t your drive has most likely failed
I had to to the whole alt thing with my Mac when I had multiple OS versions
Hopefully this helps
Score 1
Add a comment
Try erasing and reinstalling the OS, but if that doesn't help, the hard drive probably failed.
2 Comments:
She does not have the disk.
by
What about when the HDD is known to be good but the system cannot find *any* disk hardware on the internal SATA bus? All I see is DVD (ATA) and externals.
by
Add a comment
Add your answer
Felicia Haze will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 500
