The Epson Stylus Photo 1400 Inkjet Printer prints high quality prints of up to 13" x 19". In addition, it supports cd/dvd printing.
18 Questions View all
Printer not accepting new black ink cartridge
The printer was flashing that I was out of Black ink, replaced with brand new cartridge and reset, but printer will not clear and accept new cartridge. Tried replacing the new one thinking maybe I had a faulty new cartridge, but it still will not accept the new cartridge (black).
Score 1
Add a comment
From Epson Stylus Photo 1400 FAQ on Epson.com
Q:
I replaced an ink cartridge and my printer still shows that ink is expended. What should I do?
A:
If you have just installed a new cartridge and you still see an ink related error, the cartridge may be incorrectly installed.
Follow these steps to make sure the cartridges are correctly installed:
Make sure the CD/DVD tray is not inserted in the printer.
Make sure the printer is turned on, but the green power light is not flashing.
Open the printer cover.
Press and release the ink button. The power light begins to flash.
Caution:
Do not hold down the ink button for more than 3 seconds or the printer will start to clean the print head.
To avoid damaging the printer, never move the print head by hand.
Open the cartridge cover.
Press down all the ink cartridges until they click into place to make sure they are properly seated.
Note:
If a cartridge is properly seated already, you may not hear a click.
Close the cartridge cover.
Close the printer cover.
Press the ink button. The printer begins charging ink.
The green power light flashes and the printer makes noise. Charging takes about two minutes. When it’s finished, the green power light stops flashing and stays on, and the red ink light goes out.
Caution:
Never turn off the printer while the green power light is flashing, or you’ll waste ink.
Add a comment
hi my epson 1400 recognises the cartridges but will not see them as full in the ink monitor
Add a comment
Add your answer
doorlatch2003 will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 5
All Time: 10,195
