Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2396 Questions View all
not charge, not able to restore, cannot turn on
Please see photos first,
This iPhone 4, after I turned it on for 15 minutes, it screens turned out like as shown in these photos.
And now the phone is completely black. I left it charge for a day and now I couldn't even turn it on.
I tried to restore and iTunes keeps showing error "1601".
I would like to order the part from you to fix it, but I need to know which one to buy. Please help me out!
Thank you so much in advance,
Regards,
Score -1
1 Comment
Thanks for your detail guideline oldturkey03.
Actually I did followed the restore trouble shooting for error 1601 & 1604, but no luck.
You have mention about the usb time out. Is that something I can repair such as changing the internal usb hardware?
I know for sure that problem is not caused by bad LCD.
by
Add a comment
1 Answer
Chosen Solution
Alex, the 1601 error is being treated the same as a 1604. Follow what Apple has to say about it first "This error is often related to USB timing. Try changing USB ports, using a different dock connector to USB cable, and other available USB troubleshooting steps (troubleshooting USB connections. If you are using a dock, bypass it and connect directly to the white Apple USB dock connector cable. If the issue persists on a known-good computer, the device may need service.
If the issue is not resolved by USB isolation troubleshooting, and another computer is not available, try these steps to resolve the issue:
Connect the device to iTunes, confirm that the device is in Recovery Mode. If it's not in Recovery Mode, put it into Recovery Mode.
Restore and wait for the error.
When prompted, click OK.
Close and reopen iTunes while the device remains connected.
The device should now be recognized in Recovery Mode again.
Try to restore again.
If the steps above do not resolve the issue, try restoring using a known-good USB cable, computer, and network connection." from here. I have had a 1601 and 1604 with a bad battery before as well, get one of those from here, as well as many other places, just to make sure. Do make sure that you have a good, and proper, cable. This error really should not interfere with your LCD. Looking at your images, I am not quite convinced that it is the LCD, but I would replace the front display assembly anyhow. Follow this guide and the part is available right here, as well as many other places. While you do that, check all the cables as well as the connectors for any corrosion or damage to the pins. Hope this helps, good luck.
iPhone 4 Battery Image
Product
iPhone 4 Battery
$11.99
iPhone 4 (GSM/AT&T) Screen Image
Product
$24.99
1 Comment:
Thanks for your detail guideline oldturkey03. Actually I did followed the restore trouble shooting for error 1601 & 1604, but no luck. You have mention about the usb time out. Is that something I can repair such as changing the internal usb hardware? I know for sure that problem is not caused by bad LCD.
by
Add a comment
Add your answer
Alex will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 3
All Time: 2,024
