The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
459 Questions View all
No service after lcd digitizer replacement!? (Tmobile)
Have fixed over 20 GS3s in my day, and this of course is my own personal one. After the screen was replaced, I only get service in WIFI areas. One/Zero bars everywhere else. Replaced sim card and even antennae. Still happening. I noticed a bit of water damage and scrubbed it. STILL didn't help. Any advice please? Maybe software? Or a chip may have broken off? Thanks in advance.
Score -1
Add a comment
Chosen Solution
Turns out the back housing had accidentally been swapped with a verizon, which seemingly fit, but later would knock the antennae off as well as not matching with some of the important grounds. Thanks
Score 1
Add a comment
Sir can you help me? I have the same problem but I don't know how to fix it. How did you fix your problem?
Add a comment
Hi Julia when you open it up there is a long cable running up the right hand side make sure it's connected proporly
1 Comment:
but is it the wifi antenna your are reffering to?
by
Add a comment
@con arent you referring to the wifi antena?
what antena or part should i look for the network issue?
Add a comment
Add your answer
Austin Harris will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 7
All Time: 1,771
