belt diagram for model 917253725 sears tractor
model 917253725 sears riding tracter do you hace a belt diagram for the drive bellts mine broke i can't figure how it goes back 2nd drive belt.
thank you
thank you
john, see if this works for you:"
BELT REPLACEMENT
The belts on this tractor are special for this application,when replacing Belts always replace with Sears belts.
a, Disconnect Negative Ground Battery Cable
b. Set Parking Brake.
c. Pull Varidrive Control Lever to slow position giving Primary Belt slack.
d. Remove Primary Belt from Engine Puley (Fig. 34)_
e. Remove 3 Bolts and Nuts holding Primary Idler Sheaves to Frame (Fig. 33).
f. Remove Klip Ring and Washer from Variator Pivot Shaft (Fig° 34) Slide Pivot Arm inwards.
g. Remove Belt from Variator Sheave.
h. Remove Idler Nuts and Idler Sheaves from Primary Idler Sheaves (Fig, 34}.
i. Primary (Front) Belt can now be removed,
j. To replace Secondary (Rear) Belt move Varidrive Control Lever to fast position, Remove Variator Belt Keeper (Fig. 34) and remove Secondary Belt from Variator.
k. Remove Clutching Idler (Fig. 34).
I. Remove Transmission Pulley Belt Guard Belt can now be removed from Transmission Pulley.
m. Reverse the above procedures to install new Belts. Replace Primary Idler Package, Belt Keeper, Clutching Idler and Transmission Pulley Belt Guard°
n. Connect Battery.
Hope this helps, good luck.
Hi john,
Go to this side and, for a better viewing, download the manual.
The manual, however, is for model 917.253724. But it might work anyways. The belt diagram is on p. 12.
Steffen
Past 24 Hours: 6
Past 7 Days: 18
Past 30 Days: 58
All Time: 7,840
