The Asus Padfone 2 was announced on October 16 2012 and is the successor to the Asus Padfone.
16 Questions View all
Dust on back camera
HI, i'm a proud padfon 2 owner, but after few months of use, I notice some dust on my back camera...wow!!!It's terrible!
Can you post a guide on how to clean the back camera?How can I try to do it?thank you.
Score -1
Add a comment
Chosen Solution
Hi! Just go to step 5 in this guide, without disconnecting the battery. Asus Padfone 2 Screen Replacement
2 Comments:
Hi! The protective camera lens just lays on top of the camera, so lay it back. Will make a guide sunday evening anyways! :)
by
Im looking into a sultion using Photo-album-sticky stuff. Replacing my screen as soon as i get it, will try it then, and make a guide! :)
by
Add a comment
I have the same problem, a guide would be nice :-)
2 Comments:
Jonatan:
Well, I can see the Camera, but it also states that "Note that the protective camera lens will get loose!"
Right, I am not a technical genius, but how do I fasten the Protective camera lens again?
by
Hi Jonatan
Do you have any good ideas how to prevent dust in the future?
Is it possible to seal it somehow?
by
Add a comment
To stop dust getting in, jam "something" in the headphone jack. I found that cutting an old headphone plug off ( the part you put in the jack ), and then inserting it in backwards ( ie rubber bit in 1st ) and then cutting the rest down to an appropriate size works well. There are apparently plugs you can buy, but I can't find any locally. I guess you could also use bluetack or chewing gum or something :P
Add a comment
Add your answer
Defteros will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 4,031
