The XV20 series of the Toyota Camry is Toyota's 6th generation of the Camry sedan.
64 Questions View all
Fan only works on high
Hello,
My fan switch only works on high so I know it is not the motor but probably the switch. But I do not know how to remove the dash cover to get to the switch. Do I have to take the entire dashboard off? Or is there a simplier way to access the switch. This would help me to replace the lighter plug that has not worked for 10 years. It is a 2001 Camry LE.
thank you
corey
Update
Thank you very much for your help. It makes sense that the resistor is out and therefore the blower only works at high speed. I will trace the wiring back to the resistor.
One questions though, how do I remove the center counsol to get to the blower? It seems like the entire cover is attached to the dashboard so I hope I do not have to remove the entire dashboard. Is there a key screw to remove that allows the cover plate to be remove to expose the blower?
thank you again for your help.
corey
Add a comment
1 Answer
Chosen Solution
Corey, the blower motor speeds are controlled by the Blower Motor Resistor. When the Resistor fails, current goes right thru it and the blower only operates at max. speed. Replace the resistor should fix this. Locate the electrical connector to blower motor, trace back wiring no more than 8" to next plug. The device where the plug is connected to is the Blower Motor Resistor. Disconnect the plug and remove the two screws, remove and replace Resistor. We'll have to figure out your lighter plug later:-). Hope this helps, good luck.
Score 2
5 Comments:
Thank you for accepting my answer. The blower motor/resistor is beneath the glove box. Check this video. Not a bad job, but kind of tight. No reason to take of the dash...:-) best of luck to you
by
Thanks, it worked great! I think it's a design flaw, moist intake air for cooling the resistor causes rust & corrosion! Didn't need the angled screwdriver when I pulled the carpet down a bit & could get a better angle; used a large jeweler's crosspoint.
by
Oldturkey03,
Thank you very much. This is exactly what I needed. It is even more perfect since it is a video and shows exactly where I need to work.
Thank you for all your help. I will try it over the weekend but am sure it will work.
thank you
corey
by
you are very welcome :-) best of luck to you.Oh yeah, welcome to ifixit :-)
by
OldTurkey03,
Thanks again for the help and the welcome.
corey
by
Add a comment
Add your answer
Corey will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 40
All Time: 21,164
