Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
794 Questions View all
Question Closed
Replaced topcase now battery won't charge
I replaced the topcase and now battery will not accept a charge. Works fine while plugged into outlet. Magsafe does not light up unless I plug into another MBP prior to connecting it to the repaired one, and only lights up for a few seconds. Ive reset the SMC and checked battery status, says in good condition.
Prior to replacing topcase battery was fine.
Add a comment
Chosen Solution
Double check that connector, and the cable for proper fit/damage. Many times people damage connectors tearing them from the logic board, or, think that they have a good connection when it isn't completely square or "clicked" in.
Score 1
1 Comment:
Thanks for the reply, but no luck. Works fine when plugged into outlet. Nice desktop huh?
by
Add a comment
Download and run Coconut Battery and let us know your results. I suspect your MagSafe board or your connection from the MagSafe board to the logic board. http://www.coconut-flavour.com
Score 1
2 Comments:
I installed the battery into another MBP to fully charge & reinstalled into defective one.
Current charge 4965 mAh
Maximum charge 4992 mAh
99%
Current capacity 4992 mAh
Design capacity 5770 mAh
87%
Mac Model MacBookPro 7,1
Age of your Mac 28 months
Battery load cycles 393
Battery temperature 29.4C
Battery power usage -0.0 Watt plugged to AC
Battery power usage 3.6 Watt
by
Replaced DC board..still no dice.
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 268
