Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2399 Questions View all
Question Closed
No sound from external speaker!
I have been having this problem for over a week, my iPhone 4 will not ring, sound the alarm, or play music. It only vibrates and makes a very staticky sound.. Has anyone has this problem and fixed it? My phone is only about a month old!
1 Comment
Thank you for all your help! I am going to try everything mentioned
by
Add a comment
Most Helpful Answer
I agree, replacing the loudspeaker is cheap and SUPREMELY easy. Here's an instructional on how to do it https://www.youtube.com/watch?v=gjoi0u3y.... Also there could be an issue with your docking connection. Try cleaning that.
Score 1
Add a comment
Hi,
I had once this problem.
I disassembled the speaker enclosure and put some electronical cleaner (spray) in the speaker...
After letting it dry, I reassembled the phone and all worked fine again....
Hope this will help you
Add a comment
My recommendation is to replace the loudspeaker. It's very cheap, and fairly easy. Ifixit has a great guide for that, if you aren't afraid to open her up. The part is definitely under $10.
Add a comment
Had this problem for almost two months. Could hear phone ring and use speaker phone , but could only hear music and apps via headphones.
Tried all those cleaning solutions, wanted to downgrade OS.
Then it got fixed and I think it was this, as crazy as it may sound.
I was nervous about having FindiPhone hooked up - my wife left hers in a restaurant and it was not hooked-up. So I checked my "Find iPhone" set up, paged the iPhone via "Find iPhone"- and ..... sound came out of the f*#$&ing speaker!
It's now all fixed - sound works in the speaker for all apps.
This is the only thing I can think of that I did that was different from all the other recurring loading, connecting etc. operations. Would love to hear if this works for others.
Add a comment
I had this problem and first changed the headphone jack out and still had the problem.....with more searching I saw a post about the docking port causing this issue. I just changed the docking port and all works well now.
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 5,030
