Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Questions View all
Stuck in white screen with broken home button!?
Please help me! One week ago, i jailbroke my ipod and it got stuck in apple logo. and i cant restore it in itunes and also all the solutions i've found needs home button. but my home button is broken... then i tried to fix it by opening the screen of my ipod. only to find out that the home button (color gold inside) is already broken. so i cant fix it. then i tried to restore in itunes and it worked! but the problem is.... the screen is pure white. i tried 10 times restoring it but nothing happens. i jailbroke it again then restore but nothing happens. so my problem is how to get out of white screen with broken home button. and i think theres a wire in the screen that is not properly attached. (my thoughts). so what maybe the problem of this? and how will i fix it? tnx. godbless.
Add a comment
Chosen Solution
I would pop it open and reseat the LCD connector which you can find in the guide here for replacing the screen for your ipod. Most likely though you will also need to try a hard reset (holding both home button and power button for 10 seconds). So i would order a new home button flex cable and replace it while you are in there. Its very easy to replace and again, the guide here will show you how.
Hope this helps.
1 Comment:
gizmo4sal3 what is a LCD connecter and a hard reset??????
by
Add a comment
Same thing happened to my Iphone 6 last night with broken home button. You don't have to do any surgery to your iphone, ipod, or ipad. I would suggest you safe yourself the stress, money to repair or troubleshoot and your time. Just let the battery run down on whichever device you are using automatically, if so listen to music on it all day. And when you're charging your device it will continue working normally.
1 Comment:
how would you be able to listen to music , if you cant use your phone?
by
Add a comment
This does not make since the phone is broke duhhh
Add a comment
Add your answer
Ivan Kennedy Puda will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 6
All Time: 7,691
