The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
459 Questions View all
water damage no sound
Hi, i dropped my S3 i9300 in water, i opened it and let it dry for a day post that i cleaned all the connections and put it back together,, made certain all is connected nicely.
So the phone is working fine the touch is good, camera is good, i can send and receive sms, chat i can brows net,, etc
The problem is..
there is no audio on the mobile, i cannot listen to any music, no ringer, no sound, only vibration ..
i cannot make or receive call, the call goes through technically, no no audio,, so cant listen on talk..
Please help
Score 5
6 Comments
did you ever get an answer to this? i have the same problem
by
Me too! Someone HELP!!!
by
Same here man only with my samsjng s4
T
by
My Samsung 1612 dropped in water and it's sound system does not work.
by
My LG k 500 n dropped in water yesterday.
I'd put it in charge.
My sound system is not working.
by
Show 1 more comment
Add a comment
Chosen Solution
Hi gill,
Here are some suggestions:
1. Does the phone work on headphones/earphones?
2. Is the flight mode switched on?
3. Have you tried the app SoundAbout?
However, since your phone experienced a water damage, there could still be water on the motherboard that causes this issue. I recommend taking the phone apart (using this guide). Now lay the motherboard into isopropyl alcohol (90%) for about 10 minutes, take it out of this "bath" and let it dry for a couple of days next to a warm source (air conditioning, for example). Put everything together again and then test it again.
Steffen
Score 3
1 Comment:
It's not a phone it's a tablet
by
Add a comment
Same thing happened to me. I poured a little isopropyl alcohol into the bottom two holes and now everything works fine. DON'T BE AFRAID. Alcohol does not conduct electricity!
2 Comments:
Hi there, this is a little late but can you give the exact steps of what you did?
by
Yes...please elaborate....did you have to some how get the ipa out afterwards?
by
Add a comment
Add your answer
gill will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 91
All Time: 50,084
