Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
310 Questions View all
Question Closed
it will do nothing when the power button is pressed.
I'm fairly new to imacs but I'm very interested. Let me ask you this, if the iMac doesn't have a hard drive at all and I push the power button, what would the iMac normally do? Right now it will do nothing when the power button is pressed. I can see the LEDs on the board and 1 stays lit the whole time.
Add a comment
Chosen Solution
WIthout a HD you'd get a "?" on the display at boot meaning no System Folder found. If LED 1 is the only one that lights you have a good power source, LED #2 Indicates that the main logic board has detected proper power from the power supply when the computer is turned on. This LED will be ON when the computer is turned on and the power supply is working correctly. So it would appear you have a faulty power supply problem.
If this Answer is helpful please remember to return and mark it Accepted.
Score 1
Add a comment
LED #1
• Indicates that trickle voltage from power supply has been detected by logic board. This LED
will remain ON whenever the iMac is connected to a working AC power source. The LED will remain on even when computer has been shut down or put to sleep. The LED will turn off only if AC power source is disconnected or power supply is faulty.
LED #2
• Indicates that logic board has detected power from power supply when computer is turned on. This LED will be ON when computer is turned on and power supply and voltage regulators are working correctly.
LED #1 = Power available.
If no LED is visible:
• Verify AC source
• Verify known-good AC cable is connected
• Verify cable connection between AC inlet and power supply
• Verify cable connection between power supply and logic board
• Verify power supply
LED #1 + LED #2 = Power available, and system is powered on.
'''If second LED is not visible when power button is pressed:
• Verify power button connection to logic board
• Verify power button functionality
• Verify logic board'''
Couple of checks you can do:" Disconnect AC cable then remove power supply and
carefully inspect connectors between AC inlet and power supply, then DC connectors and cables between power supply and logic board, for damage or poor connections.
Inspect power button and verify if it is properly connected to the logic board
Disconnect power button from logic board. Inspect cable and connector for damage. Verify continuity between the two pins of power button when it is pressed.
Press power button and Verify if system turns ON. You may alternately check for presence of a 12V DC signal between pin 11 and pin 1 of logic board when power button is pressed. If not, Replace DC power cable." Remember, I am not a Mac person, just a person who enjoys hardware from any manufacturer. Hope this helps, good luck. Hope this helps, good luck.
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 672
