Released on November 22, 2005, the Xbox 360 wireless controller is the primary game controller for the Microsoft's Xbox 360 home video game console.
90 Questions View all
My left analog stick is not working properly
My Xbox 360 left analog stick is not working properly. Although its tight and firm in its place, while left untouched, it gives a back command in the game. Would open up my controller but i dont know what to do about it after i get it open. Please help...
Score -1
Add a comment
1 Answer
Chosen Solution
sharpluck, sounds like a bad stick. I would suggest to replace the stick with a set of new ones. They are relatively inexpensive and it only requires basic soldering skills to replace them. You can also try to reflow the solder connections of the joystick. If that does not help it may be time to "replace the controller. They are available on places like this. On the how-to part, here is my answer from a similar question. "use this as a general guide. All you need to do, is to unsolder the connector and solder the new joystick in place. It should be a straight forward repair. Of course, you'll need a soldering iron, a desoldering wick (or solder sucker, flux and solder to repair the joystick...Hope this helps, here is a great tutorial. hope this helps, good luck.
Score 2
2 Comments:
Thank you so much for your help...will try to follow d tutorial n resolder:)
by
Sounds good, let us know how it is going.
by
Add a comment
Add your answer
sharpluck will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 11,396
