No power to the machine?
Started using our machine again . Worked fine yesterday . Added some water today & nothing when u press the start button . Opened it up & didn't see any excess water on any of the parts ... So
For starters I would try it on another outlet that you know to be good (test it with another device), and if you have it on a GFCI outlet then make sure it isn't tripping the breaker.
If you've verified the power source if fine, after turning the machine on and waiting 5-10 minutes, do you feel any heat coming from the top of the machine or the brew head? Does the green "ready" light come on?
If so, but pushing the brew button doesn't do anything, then you could have a bad brew button or a seized pump.
If you don't feel any heat then you probably have a ruptured heating element. If the machine sat for a long time with water in the boiler then scale buildup on the heating element was most likely the cause of this.
you have power supply problem
first check mains volt coming in to the coffee machine if yes then trace where the voltages go, if it is going in the main board then you need to repaire the electronic board.
On the main board check for main fuse and other active components.
if you are not well versed with electronic board then give it to someone else
Ashwin
I don't like to downvote people but this is pure and simple bad advice. This machine does not have a power supply or any kind of circuit board in it, only simple mechanical switches and thermostats. Please try to at least familiarize yourself with the device in question before dispensing repair advice.
Did you manage to resolve?
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 38
All Time: 3,682
